saginaw 3pt hitch on 43 h
Randy
11-03-2003 22:54:06
I have a 43 farmall H that I want to put a saginaw 3pt hitch on and want to know if any of you have done it and does it work with existing hydraulic belly pump or do I have to use an aftermarket pump if so what and where to buy. Help me I love this old H and want to make her attachment friendly.
dave in virginia
11-04-2003 20:10:29
 Re: saginaw 3pt hitch on 43 h in reply to Randy, 11-03-2003 22:54:06
I bought one a year ago for my 52 H.I Love it!the dual cylinders and heavy build will easily raise
the frontend off the ground,(no weights)when loaded too heavy on the boompole.yeah I learned the hard way.Installation was easy. I had to get a couple of hyd. hoses and fittings from the local farm store,and bolt it on.With this I also get to keep the original drawbar for those heavy dragging jobs,and it uses the belly hydraulics already on the tractor.
26Red
11-04-2003 13:24:13
You can plumb a hyd control valve(3 way)into your hydraulics to give you total control(up&down pressure)for your 3-pt hitch. Plumbing part is easy, hard part is mounting the hydraulic valve in a handy spot.
Steve - IN
11-04-2003 02:42:29
Randy,
Even the older low pressure belly pumps on an H can do some pretty impressive things. Just don't expect it to do them rapidly, and you should be happy.
Allan
11-04-2003 02:23:19
Hi Randy,
Should go right on there and you should be able to use your existing pump.
What part of NE?
Allan
