706 Rear Pump rebuild, salvage, parts?
Adam Whitson
11-05-2003 12:39:25
The rear pump on my 706 failed. Are parts for this pump (impellors and seals) availible, or should I check with salvage yards for a used one.
Will an 806 pump work as well?
ABW
Larry B
11-06-2003 05:58:30
 Re: 706 Rear Pump rebuild, salvage, parts? in reply to Adam Whitson, 11-05-2003 12:39:25
The rear pump out a IH tractor,706 thru 1466 and most 86 series will fit. The only difference on some is the gal.per min. I have bought a good used one for $100.00 last spring out of D&S, a salvage yard in Sikeston MO.
Aces
11-05-2003 20:33:37
The 706 806 should have same pump I never tried rebuilding a pump so can't help you there
