What do ya do with all the left overs?
Dave@NY
11-05-2003 17:01:16
Been giving serious consideration to building one tractor out of two.One running,one not.These are Regulars,wide tread and narrow.Want to end up with a narrow tread for all the usuall reasons.In the process of picking the best of the parts,there will most of a tractor left over with some not so good parts.So--put it all back in one piece for storage,or sell it off.Must be some guys sell them piece by piece on E-bay.I would never sell the remains to the scrap man.Storage at present time is not a problem.Hmm-what do you fellows do?
rustyfarmall
11-06-2003 10:26:40
 Re: What do ya do with all the left overs? in reply to Dave@NY, 11-05-2003 17:01:16
Keep all those leftover parts, might be just what you need for the next project, and there will be another project.
FM
11-06-2003 04:39:02
Buy the parts you need to fix the second one enough to get it running, then sell it.
Mike
sod
11-07-2003 07:06:17
 Re: Re: What do ya do with all the left overs? in reply to FM, 11-06-2003 04:39:02
Yeah, you already have one that runs. Anything that one might need should be relatively inexpensive. Fix up the other and sell it.
good luck
sod
Dave@NY
11-07-2003 14:29:00
 Re: Re: Re: What do ya do with all the left overs? in reply to sod, 11-07-2003 07:06:17
Will need a piston,set of rings,set of valve guides,3 or 4 valves,manifold,carb,magneto,fuel tank,lines,rear wheels&tires,brake linings,radiator,air cleaner.This is just the mojor parts.See what I mean about having to find another parts tractor to revive this parts tractor!I might just put it back together in one piece after the main project is done and stash it for future reference.As long as my storage holds out that is.
FM
11-07-2003 16:45:13
 Re: Re: Re: Re: What do ya do with all the left ov in reply to Dave@NY, 11-07-2003 14:29:00
I kinda figured it was indeed a "time and money" thing. Happens a lot ;-) I hope you either keep it or find it a good home. just don't send it to the crusher...
Mike
Dave@NY
11-07-2003 02:48:02
Its kind of a time and money thing.Besides I'd about have to find another parts tractor to fix up the donor tractor.But I see what you are getting at.
