mag/dist cap wire diagram
Jim
11-06-2003 09:13:24
I goofed...
I removed my magneto from my M to have it rebuilt, but forgot to make the "holes" on the distributor for the spark plug wires. Can someone help me determine where each wire goes?
Thanks,
Jim
Nebraska Cowman
11-06-2003 09:50:03
 Re: mag/dist cap wire diagram in reply to Jim, 11-06-2003 09:13:24
if it is timed the way it is supposed to be #1 is at 2 o'clock Firing order 1-3-4-2 clockwise. If you have trouble just ask we can help you retime.
Jim
11-06-2003 11:10:55
 Re: Re: mag/dist cap wire diagram in reply to Nebraska Cowman, 11-06-2003 09:50:03
Thanks!
Can I assume that #1 is on the rear of the engine (towards driver) and #4 is closest to the radiator?
Thanks, again!!
Jim
Bob
11-06-2003 11:17:23
 Re: Re: Re: mag/dist cap wire diagram in reply to Jim, 11-06-2003 11:10:55
#1 is at the front, towards the radiator, as it is on nearly EVERY in-line engine, domestic or foreign!
Jim
11-06-2003 11:44:58
 Re: Re: Re: Re: mag/dist cap wire diagram in reply to Bob, 11-06-2003 11:17:23
Thanks!!
I suppose if I did it the way I proposed, the engine would run backwards!
Okay... I'm kidding!!
Thanks again,
Jim
