WD-9, 600, 650 Starter Question
Ron in Nebr
11-06-2003 14:51:48
I'm looking at buying a 650 IH from a neighbor. It's been sitting a few years, but is supposed to run good. Someone "borrowed" the starter off of it to use on something else, and now it's gone. Are these starters specific to these tractors, or will starters off other IH tractors work, and if so, which ones?
David Saville
11-06-2003 20:10:40
 Re: WD-9, 600, 650 Starter Question in reply to Ron in Nebr, 11-06-2003 14:51:48
The starter off of a 9 will fit but the 9 used a mechanical engagement while the 600 and 650 had a solenoid. So that parts will fit you have to change some of the fuel lines as well. I was going the other way (650 starter on a 9) so you may not have to change the lines but those 9 starter pull rods are tough on your pointy finger. Can't remember right which system the super used.
Ron in NE
11-06-2003 20:53:12
 Re: Re: WD-9, 600, 650 Starter Question in reply to David Saville, 11-06-2003 20:10:40
Thanks- I know where a few 9's are that I can get parts off of if need be. Actually, I was hoping that a starter from a more common tractor, say a 560 or something similar, would work. The owner of this 650 claims the starter was taken off to be used on an Oliver....but I do know they used to have some WD-9's and I belive a TD-9 crawler on the place, so it's possible he's mistaken on what it was used on.
