REVENGE OF THE BUZZ
farmallsc
11-06-2003 16:09:08
as i posted earlier, my super C buzzes when i turn the key (i use a battery charger on run because my battery is dead)the lights come o there is a buzzing and then everything goes off and the charger is still putting out power is there a short somewhere? if so where is it likely?
Nebraska Cowman
11-07-2003 17:43:16
 Re: REVENGE OF THE BUZZ in reply to farmallsc, 11-06-2003 16:09:08
I doubt your charger is meant to start the tractor all by itself. They are designed to be a boost only. Try putting in a good battery.
Adam
11-06-2003 17:23:11
Could be lots of things:
Start Solinoid, voltage regulator, point. . . Where is the sound comming from? Dash? ENgine? Dead Battery?
ABW
farmallsc
11-07-2003 12:50:58
 Re: Re: REVENGE OF THE BUZZ in reply to Adam, 11-06-2003 17:23:11
it comes from the engins how do i fix the magneto?
Adam
11-08-2003 12:48:47
 Re: Re: Re: REVENGE OF THE BUZZ in reply to farmallsc, 11-07-2003 12:50:58
Buzzing from the engine, no distributer, has magneto. . . Well. . .
Does the buzz occure when you try to use the starter?
ABW
