M, with M W hand clutch
Marc
11-06-2003 19:41:20
I purchased an M with the M & W hand clutch a few month's ago, and it worked great for a while. Then it seemed to start slipping. The other day it finally quit. If I push the handle forward with a lot of force it will pull ahead, but only if I push it forward hard. Do you guy's know if it is just out of adjustment, or does it need replaced. And where can I get some info. on the M & W hand clutch? Thanks in advance. M. K.
ross
11-07-2003 09:43:19
 Re: M, with M W hand clutch in reply to Marc, 11-06-2003 19:41:20
I think Kelly C's website has a good bit of info on the M&W hand clutch Ross
Ross-sorry
11-07-2003 09:44:53
 Re: Re: M, with M W hand clutch in reply to ross, 11-07-2003 09:43:19
The link aparently didn't go through
Link
Ross
Stan(VA).
11-07-2003 05:47:58
If it's just slipping because of to little pressure, you can remove the small side cover and there is a large nut facing you that should be tightened to require ~30-40lbs of hand pressure to pull or push the lever. The nut will have a locking tab on it also. If it's not that, next likely problem could be the fibre discs getting their teeth chewed off. If so, they will need to be replaced. Email me for a link to a parts breakdown if interested.
Stan(VA).
Marc
11-08-2003 06:16:46
 Re: Re: M, with M W hand clutch in reply to Stan(VA)., 11-07-2003 05:47:58
Stan, I would like the link for the M and W breakdown. Mark.
