air cleaner oil C
jf
11-07-2003 11:54:39
I guess my subject states the question. What type of oil goes in the oil bath container at the bottom of the air cleaner? thanks
Noah w
11-07-2003 12:00:14
 Re: air cleaner oil C in reply to jf, 11-07-2003 11:54:39
I use whatever I put in my engine...as long as it isn't 20-50. Generally SAE 30.
JB
11-07-2003 14:10:05
 Re: Re: air cleaner oil C in reply to Noah w, 11-07-2003 12:00:14
Hi, should be non-detergent oil. Detergent oil will foam. All these tractors were made before detergent oil was available, so just used the same oil in air cleaner as crankcase.
JB
CNKS
11-07-2003 20:06:29
 Re: Re: Re: air cleaner oil C in reply to JB, 11-07-2003 14:10:05
I have detergent in all of mine, I do tend to use SAE 30 rather than multigrade, not sure it matters, except perhaps in very cold weather. The dirt is compressed in the bottom of the cup by centrifugal force, foaming shouldn't matter in this case. I believe detergent foams only when hot, it doesn't get that hot in the air cleaner, so as long as it's oil---.
