wheel size on an F-12
Digger
11-07-2003 19:40:45
I was woundering what the wheel size of an F-12 is?
Digger
11-08-2003 18:06:58
 Re: wheel size on an F-12 in reply to Digger, 11-07-2003 19:40:45
Thanks for the info. I'm going to a sale tomarrow and they have a set of F-12 flat spoke wheels for the rear looking in to getting them. :-)
Ralph
11-08-2003 17:09:33
They also came out with factory "36" tires on rear.
Dan
11-08-2003 12:31:48
Digger, are you looking for a pair of rear steel wheels? I have a set for sale.
Dan
49 Cubber!
11-08-2003 04:38:46
Front or rear,single or double front.On my 14 I have rear 40 inch rubber,front is I think 15 inch rubber.
Nebraska Cowman
11-08-2003 03:46:25
which F12?
Zak
11-08-2003 06:29:02
 Re: Re: wheel size on an F-12 in reply to Nebraska Cowman, 11-08-2003 03:46:25
Depends really. Fronts are 4.00x15's or 5.00x15's (I have 4.00's). Rears can be the expensive 40 inchers as stated, or you might have a set of H rims on it, in which case you can use 11x38's. If this is the case, you might be able to locate a set of irrigation tower tires which are less expensive than actual tractor tires, but no less effective for what we tend to use our tractors for. Zak
