!00 oil pump
Buster
11-08-2003 14:07:27
Can't seem to get the oil pump meshed with cam, wont go up those final inches. Do I need someone to gently turn handcrank while I try to slide it up or what is the proper way to get the pump to mesh with the cam?
Aces
11-08-2003 19:39:02
 Re: !00 oil pump in reply to Buster, 11-08-2003 14:07:27
Buster all you should have to do is rotate the pump body a little back and forth and it should slide right in , but need to be inline. Had the one out of my B and did not have it lined up just right at first, when I got it in line went right in.
