Value of Farmall 560 and International 37 Disc
RET
11-08-2003 15:34:01
What would be a fair price for a Farmall 560 gas with a wide front and fast hitch in excellent condition and new rear 15.5X38 tires? Also what is an International model 37 disc with a two way cylinder worth?
Hugh MacKay
11-09-2003 08:04:30
 Re: Value of Farmall 560 and International 37 Disc in reply to RET, 11-08-2003 15:34:01
Ret: On the subject of the Farmall 560. If I were buying that size of tractor, I would go diesel only. The fuel consumption on the gasser will be about 4-5 times as much as the diesel. A 560 gas will not have the working hp of the diesel either.
Disks are rather a generic item, if the dealer ordered them in new with heavy disk blades, gang bolts, spacers and bearings they are worth good money. If they were ordered in light at 20 years they are little more than scrap metal. Best thing to do in the case of a disk is compare several. Disk blades should have good thickness, 1/4" to 3/8" at the hub, still with good concave, on a 10 footer the arbor bolt should be 1.5" diameter. Spacers should be 3-4 inch diameter with a good 6 inch bell shape behind the blade. All these things strengthen the disk as well as adding the weight to make it cut good.
RickB
11-09-2003 03:43:24
Figure $50 for the disc if the cylinder doesn't leak.
Vern
11-08-2003 19:38:29
Where are you located?
RET
11-09-2003 03:42:17
 Re: Re: Value of Farmall 560 and International 37 in reply to Vern, 11-08-2003 19:38:29
I am located in Northern Wisconsin.
old
11-08-2003 16:07:49
A dealer close to me has one he's asking $3995 for it. Hope this helps some
Ret
11-08-2003 15:41:39
I forgot to mention the disc was a 10 foot.
HB
11-09-2003 06:24:53
 Re: Re: Value of Farmall 560 and International 37 in reply to Ret, 11-08-2003 15:41:39
$500 bucks for the disc-good wheel discs ain't cheap!!
HB
