Tranny Oil?? and how much for 350 Farmall?
Greasy John
11-08-2003 19:36:49
Drained the 350 B4 I tore it down had a tan/cream colored oil ( abt 70-80 Wt)What shud I use and how many gallons does it take.Every thing from the front live PTO case -T/A - transmission and finals seem to run in the same common oil-grease.!!There are no seperate compartments--just looks that way.Any help?? John in Oregon
Bill
11-08-2003 20:48:06
 Re: Tranny Oil?? and how much for 350 Farmall? in reply to Greasy John, 11-08-2003 19:36:49
Greasy John
I have the original owners manuel that came with my 350. It says: For transmission and differential case (Tractors with Torque Amplifier) Capacity approx 7 gal. SAE 75 gear oil lubricant or a mixture of 1 quart IH Torque Amplifier Transmission Lubricant Additive to each 4 gallons of either SAE-10 or SAE-10W engine oil. When temps are consistently above +40°F., SAE-80 gear lubricant may be used. (For tractor without T.A.): Capacity 7 gal approx. SAE-75 or SAE-80 gear lube or mixture of 1 quart IH T.A. Lubricant Additive to each 4 gallons of either SAE-10 or SAE-10W engine oil. When temps are consistently above +40°F., SAE-90 gear lube may be used.
Greasy John (Or)
11-09-2003 08:38:27
 Re: Re: Tranny Oil?? and how much for 350 Farmall? in reply to Bill, 11-08-2003 20:48:06
Great Info! Tnx Bill-Hytran-Dick ,Thats what I needed to know. I have eliminated the T/A A big trouble maker in my humble opinion .Tnx again all. John
Dick Davis
11-09-2003 02:54:12
Bill, you're right on for what the orginal manual said. As you can see IH was trying to deal with the moisture in lube problem then. There solution was Hy Tran and all subsequent instructions were to use HyTran exclusively. No more mixing and changing seasonally. My nickel. Dick Davis
Hy Tran
11-08-2003 20:08:16
All tractors with TA and live PTO take Hy Tran in all compartments.
