Order Farmall Cub Parts Online
CUB vs JD LA vs MH PONY
Small Battle
11-09-2003 09:05:50
I posted this in the general forum, thought I would post in the "Brand loyal" forums as well.
What do you think? State your case for your favorite!
Who would win??!!
Pulling
Versatility
Looks
Other?
jocco
11-09-2003 13:50:38
 Re: CUB vs JD LA vs MH PONY in reply to Small Battle, 11-09-2003 09:05:50
la hands down will out pull out work: yes no hydralic but li did have and a pto is optional. And yes much more stylish, comfort would go to the mh or cub. You for got the allis chalmers g it will hold its own with the la (same engine as pony). A massey harris pacer might have the advantage on engine power.
Bus Driver
11-09-2003 13:35:03
Nebraska Tractor tests list the Cub 1947 weight as 1477#. The 1941 JD LA weighed 2285#. The weight difference alone would mean that the heavier tractor would have the greater drawbar pull. The difference in field work done in a day depends on other factors. Look at the JD 830 and the 4020 as examples of that.
Dan Robertson
11-09-2003 11:23:09
I'm prejudace, but the Cub certainly has the better looks and the versatility, probably cheaper to operate too. Dan Robertson
RAW in IA
11-09-2003 14:30:05
 Re: Re: CUB vs JD LA vs MH PONY in reply to Dan Robertson, 11-09-2003 11:23:09
I go along with you on the looks department, with the pony second and the JD last in looks. Never did like the looks of the L or LA
old
11-09-2003 11:03:04
The JD will out pull the other two
