Bad Engine noises???
Dave
11-09-2003 14:56:50
Seems like I now have some bad noises coming from the front of my C and they seem to get worse as the engine starts to warm up. I am pretty sure it is not the fan although I plan to take that belt off just to make sure. At what point am I well advised to keep it shut down and to pull the pan to look for damage or bits of metal? So far I have only run it for a minute or two at a time.
Will Sick
11-09-2003 17:59:55
 Re: Bad Engine noises??? in reply to Dave, 11-09-2003 14:56:50
If its knocking don't run it any more. It could be a rod bearing or main bearing. If you keep running it you will ruin the crankshaft. It may still be good enough to regrind.
