Super A Sleeve Broke, Help!!
Mike@NY
11-09-2003 17:14:11
I ran into a problem. I just got my 3 1/4" bore sleeves back from the shop to get them matched to my block, and one of them broke when I went to install them. I still have two 3 1/8" bore sleeves left that I took out of this block. Does anyone have any ideas on how I can get myself out of this one? Anybody know of a good place that has single 3 1/4" sleeves that I can get? Any help will be appreciated. Thanks in advance.
gene b
11-10-2003 02:26:23
 Re: Super A Sleeve Broke, Help!! in reply to Mike@NY, 11-09-2003 17:14:11
Where did you get the ones you have now? You had to turn the OD down to get them in the block right? If you have the dimensions you might get one from HOWARD ENTERPRISES you can e-mail for their adress
Mike@NY
11-10-2003 04:51:19
 Re: Re: Super A Sleeve Broke, Help!! in reply to gene b, 11-10-2003 02:26:23
I got the current ones from an on-line catalog (mistake #1) and had the bottoms turned down to the needed diameter. I searched for Howard Enterprises and I found there website. Thank you for the name, they are definatly another option.
justin
11-09-2003 22:00:27
Just find an auto parts store or machine shop that deals in Clevite parts, and order a WS275 Sleeve.
Mike@NY
11-10-2003 04:48:35
 Re: Re: Super A Sleeve Broke, Help!! in reply to justin, 11-09-2003 22:00:27
The part # is for the 3 1/4" bore sleeve correct?
justin
11-10-2003 06:35:50
 Re: Re: Re: Super A Sleeve Broke, Help!! in reply to Mike@NY, 11-10-2003 04:48:35
That is for the super A above serial number 310299. This is the sleeve with the larger OD at the pilot.
