Broke high low reverse cam pivot shaft arm on Far
David
11-09-2003 17:29:40
I have an 806 International Farmall tractor. 1965 year model, I think. My high low and reverse cam pivot shaft arm broke off and I must replace it. What are things to be careful of when removing the top cover that has the shifter and oil filler on? The arm sheered off even with top plate. Also, where can this part be ordered and approximate cost?
Jim J
11-09-2003 22:39:23
 Re: Broke high low reverse cam pivot shaft arm on in reply to David, 11-09-2003 17:29:40
I have a used cam pivot shaft>
Jimmy King
11-09-2003 22:06:10
Onced you get the floor board out of your way take out the bolts you may have to pry it a little to break the gasket loose. Go the your CaseIH dealer for the parts. Cost your guess is as good as mine, as they have no rhyme nor reason.
