loader on M
stovepipe
11-09-2003 18:48:03
I'm wondering if any body knows why the loader on our M won't go down when loaded heavy. Don't know brand of loader but its a paulson look a like. We use it to haul wood so if I'm carefull and not put too much in bucket it will go down but I have to push rod all the way down.
Jim
11-10-2003 09:27:33
 Re: loader on M in reply to stovepipe, 11-09-2003 18:48:03
You may have a hose contected into the delay connection. There are a couple different connections you can make to the side of the tractor if you are using the belly pump. Might want to play with that idea. Let me know if it works. Just my 2 cents.
Allan
11-10-2003 05:58:50
SP,
I'm not familiar with your loader....But, are you using the M's hydralics?
If so, remember that the heavier the load, the more pressure it takes on the lever to 'release' the tractor's hydralic circuit.
Tryin' to read between the lines,
Allan
