Farmall C charging problem - I think
JustinS
11-10-2003 06:07:29
I think my C has a problem. The tractor use to show charging when we were using it, but lately it has stopped showing that. The battery will not stay charged, but we are able to crank start it and it runs fine. If i pull a battery cable off when it is running it dies. I'm not sure what to do next. If anyone has any ideas please let me know.
Randy inNE
11-10-2003 12:59:58
 Re: Farmall C charging problem - I think in reply to JustinS, 11-10-2003 06:07:29
I have had trouble with my voltage regulator if the battery has been disconnected for awhile. My brother 'flashes' the field. Don't remember which terminals he shorts out. There have been previous discussions about this so you should be able to find something in the archives.
Bob M
11-10-2003 06:50:08
Justin - I agree with Allan - you've got a generator/regulator problem. Assuming your C is equipped with a regulator (not a cutout), punch below for a troubleshooting chart that may help isolate the problem.
Greg
11-10-2003 13:56:24
 Re: Re: Farmall C charging problem - I think in reply to Bob M, 11-10-2003 06:50:08
Will this chart apply to my H? I am having a charging problem too. '52 H with distributer.
Bob M
11-10-2003 17:46:49
 Re: Re: Re: Farmall C charging problem - I think in reply to Greg, 11-10-2003 13:56:24
That chart will apply to your H! All the non-diesel, lettered Farmalls of that era are identical electrically.
Greg
11-11-2003 04:27:56
 Re: Re: Re: Re: Farmall C charging problem - I thi in reply to Bob M, 11-10-2003 17:46:49
Thanks
Mitchell Pool
11-12-2003 17:02:16
 Re: Re: Re: Re: Re: Farmall C charging problem - I in reply to Greg, 11-11-2003 04:27:56
It has to be repolarized, just go to the local repair shop or ih dealer and they will tell you how.
JustinS
11-10-2003 10:57:39
thanks for the help, i will see what i find out and keep you posted.
Allan
11-10-2003 06:30:27
Justin,
Yep, you have a generator/regulator problem.
You should be able to take the battery completely out of the tractor with it running at an off idle speed and it shouldn't make any difference, whatsoever.
Allan
