300 Utility hydralics
Carl in WI
11-10-2003 14:27:13
I have a IH 1955 300 utility tractor and it has a spare hydralic valve mounted on the hydralic oil tank under the seat. What was this intended for? The rear valve is used for the hitch. Thanks
Carl in WI
11-11-2003 06:10:24
 Re: 300 Utility hydralics in reply to Carl in WI, 11-10-2003 14:27:13
I figured the spare valve was for other uses. I am going to pipe to the rear for a remote. I also noticed that the valve seems like it is stuck. There is no valve action when you pull the leaver. I will have to take it apart and clean it up.
Carl
Red Rider
11-10-2003 19:32:27
My 300 Utility has three hydratouch valves. Like you mentioned, one is for the fast hitch and the other two were for external hydraulics. I have plumbed these two to the rear of my 300. My blade has a hydraulic side shift and leaveling wheel 4 feet behind the blade. With the tail wheel you have perfect control of the blade height.
