front end loader 195? 300 utility international
bbarnes
11-11-2003 13:23:30
i need the part that the loader attaches to that is bolted to the front of the tractor. The loader attaches to the rear axle. The loader has a bumper/grille guard attached to it and it appears that the tractor is connected to the loader by means of the needed part sliding into the bumper. it would be greatly appreciated if i could get any info on where i could get the needed part or even view the part so i could manufacture my own. I am from rural southeast alabama where farm tractors can be found pretty easily. I would be more than glad to keep my ears and eyes open for anyone interested in a used tractor or implement.
Ben in MN
11-11-2003 17:41:39
 Re: front end loader 195? 300 utility internation in reply to bbarnes, 11-11-2003 13:23:30
I have a couple pictures that may help you. It is just a couple of plates that bolt on either side of the from bolster. The plates have two bolts in them. There is a piece of 3/16"x1" bent into a U shape and welded to the plate. There is also another piece welded between the two legs of the U.
The pictures are with the tractor loader installed. I may have a few pictures without the loader on as well, but have to look for them. If you email me, I will send you the pictures.
