quick hitch yoke
Cletis
11-11-2003 15:34:34
I tried the dealer and they want 70.00 for one. It is the connector piece that connects the quick hitch bar and the other piece that bolts behind the rear wheels. this piece is close to the middle underside of the tractor. wish i had a picture. It goes on a Farmall 100. Thank you. It is connected by a horizontal pin for the quick hitch bar and a vertical pin on the other piece. Thanks. Cletis
Lewis
11-11-2003 16:28:34
 Re: quick hitch yoke in reply to Cletis, 11-11-2003 15:34:34
Hi Cletis,
I can't help you in locating the part, but I can tell you I have a 100 and a Super A, both with the fast hitch. I know the part you are referring to and I believe you could make one if you are not strictly after the original part. Is yours broke, missing? I can't post a picture, but I could take some measurements if you need them. By the way, once you use the fast hitch, you won't want to use any other. Hook up and un-hook without ever leaving the tractor seat. The only problem its hard to find the implements at a reasonable price. Hope this helps.
