IHC M fuel gauge-type gas tank cap repair
zooeyhall
11-11-2003 16:24:56
I have an M that has the fuel gauge type filler cap (the one that has a cork float on it and a fuel level gauge in the top). I need to have a repair done on this gauge (there is a looseness with the indicator needle, which causes the gauge to show an incorrect fuel level). Does anyone have any suggestions on where I might get this done? Thanks!
Tom
11-12-2003 10:17:27
 Re: IHC M fuel gauge-type gas tank cap repair in reply to zooeyhall, 11-11-2003 16:24:56
If you will describe your problem in greater detail, I may be able to tell you if your gauge is repairable. Parts of the gauge are non-serviceable, mainly the indicator dial under the glass. I have some NOS cork float assemblies, if your float is the problem.
Tom
BIG JOHN
11-11-2003 16:47:07
Not for sure but try Tom Underwood, 1320 Spencer Dr, Lawrence, KS 66047, 785-749-5231. I seem to remember that he had NOS Corks for these guages maybe he will have what you need.
GOOD LUCK
