smokin D179
john
11-11-2003 17:44:43
hello, i have a 3 cyl d179 diesel in a 474 and it smokes bad, but runs real good .plenty of power ,good starts in cold weather,idles very nice.could it just be valve guides/seals?thanks for any comments,john.
JB
11-11-2003 18:53:27
 Re: smokin D179 in reply to john, 11-11-2003 17:44:43
Hi, does it use any crankcase oil? If it was out of time it would smoke but I dought if it is out of time because it starts good. My brother has a 454D that has the same 3 cyl 179D in it. It has well over 10,000 hrs on it and it doesn't use a drop of oil between changes. It smokes a bit of Diesel smoke when it is not warmed up. Is your thermostat working properly to keep the engine up to proper running tempature? The other thing is these engines can easily be over fueled by adjusting the fuel shut off stop screw on the injector pump. If yours is smoking because of over fueling, you can test this by not pulling the Stop/Start/Run lever all the way to the top of the Run position.
Let us know what you find.
JB
john
11-11-2003 20:59:37
 Re: Re: smokin D179 in reply to JB, 11-11-2003 18:53:27
j.b., thanks for the reply,the engine uses some oil but not what i would consider a lot{4500 hrs}
and come to think of it the temp doesn't really get up to temp till you go out and work it.i'll replace the thermostat.and also if i leave the lever down a bit it should clear up the smoke if it is over fueling?
