Farmall B Front Wheel Removal
John Konwiser
11-11-2003 20:37:10
To change the tire on a single wheel "B" tractor looks like all one must do is pull the bolts on the underside of the clevis and lift the front end and the wheel assembly will drop down. Is this correct and if not what is the procedure?
gene b
11-12-2003 02:54:34
 Re: Farmall B Front Wheel Removal in reply to John Konwiser, 11-11-2003 20:37:10
Should work but things get worn and rusted up and dont always come apart great. But that rhould let the wheel fall down enough to get off for repair.
