farmall 560 TA question
mark
11-12-2003 07:48:59
Got a 560 with a bad TA. It works fine in the forward position, I assume that is high side. Is that a very big job to fix and will the high side eventually go out as well? Thanks.
Aces
11-12-2003 10:21:28
 Re: farmall 560 TA question in reply to mark, 11-12-2003 07:48:59
To repaire the TA you will have to split the tractor twice and remove the TA housing. the high side will last a long time if you keep the clutchs adjusted.
