m hydraulics
allen
11-12-2003 09:15:00
how do you plumb a m with belly pump to operate a double acting cylinder?
FarmallH42
11-12-2003 10:52:20
 Re: m hydraulics in reply to allen, 11-12-2003 09:15:00
See this website, click on H and M hydraulic tricks.
http://www.geocities.com/farmall544
Aces
11-12-2003 10:18:42
Allen use one of the pressure ports from the belly pump and go to the in port on a two way valve and from the out or tank port back to the belly pump fill or drain plug. when you want to use the 2 way lock the belly lever back for raise then use the 2 way, if you want to use the belly pump lock the 2 way one way or other.
