Order Farmall Cub Parts Online
cub hydraulic problems
Scott
11-12-2003 17:47:56
I have a 1967 international cub with hydraulic problems. I installed a pressure gauge in the high pressure side of the pump. As the control lever is raised or lowered, the pressure comes up from ~30 to ~60 psi. The rockshaft will move up until it starts to pick up load, then it stops. When lowering, it moves very slow and you have to pull down on the rockshaft. The pressure never goes above 60, and returns to 30 if you center the control lever. I suspect the pump is bad, but is there a way to verify this before purchasing a new pump? Are there cheaper places to purchase pumps for this tractor than the dealer?
Any help would be appreciated.
Bigdog
11-12-2003 19:33:06
 Re: cub hydraulic problems in reply to Scott, 11-12-2003 17:47:56
Rebuild kits are available for that pump from IH dealers. They are reasonably priced and the rebuild is easy to do. From the readings you indicate, the pump is barely (if that) working.
Scott
11-15-2003 05:45:29
 Re: Re: cub hydraulic problems in reply to Bigdog, 11-12-2003 19:33:06
My maintenance book talks about a rebuild kit for the pump, but says it only includes seals. No hydraulic fluid is leaking past the main drive seal into the engine crankcase. Could the small seal rings cause this much loss of performance? The mechanic at the dealer said the aluminum housing can wear causing blowby. Is he just trying to sell me a new pump?
Thanks for your help.
