424 International Charging problems
Mark A. McCall
11-13-2003 04:02:36
I have had the generator checked on my 1965 424 International. I have also replaced the voltage regulator. After I replaced the voltage regulator, I noticed that the primary wire leading into the wiring harness from the BAT terminal of the voltage regulator had disintegrated. It looks as if it merged into one of the wiring harness connectors, so I spliced it into one of the wires, where it looked as if it had broken off. That blew out the AMP light when I revved it up, so I undid my splice and ran the BAT wire through an amp gauge straight to the battery terminal on the starter. Now, it still is not charging and the AMP light will come on and begin to glow brighter as the engine is revved, but does not go out. It is still not charging. Anybody know what I am doing wrong? I tried to polarize the voltage generator, but when I touched the short wire to teh BAT and ARM terminals, I saw no palpable spark, and the wire did not get hot. Could this be the problem?
Bob M
11-13-2003 12:03:58
 Re: 424 International Charging problems in reply to Mark A. McCall, 11-13-2003 04:02:36
Mark - It's possible you ruined your new regulator. More likely however it's problem (open, short or wrong connection) in what's left of the wiring harness. I'd recommend tear out the old harness and replace it with a new one. Or if you are so inclined and have a diagram, make up your own new harness.
Mark A.McCall
11-14-2003 03:37:23
 Re: Re: 424 International Charging problems in reply to Bob M, 11-13-2003 12:03:58
Bob- I was lucky. I got to fooling with that thing last night, and the problem was the plastic three wire plug. I got it fixed, and it is now charging.
Thanks!
