560 power loss. What to do about it?
Farmall Daddy
11-13-2003 07:35:46
I just reecently dynoed my 560 gas. It has the original piston set in it that was sent from the factory. It only had 55 horsepower from what the dyno said when the motor was cold. As the motor warmed up, the power went down to 50. Should I overhaul it with the bigger piston set, or keep it original. I use it around the farm, and occasionally for pulling in the 10,000lb class at tractor pulls. Never had a problem with power loss in the 10,000 first gear, torque back. Pulled good, but my compression rings are bad. What size of oversize piston will fit without boring the motor to a 301 cubic inch? Thanks for the response!!
rustyfarmall
11-13-2003 10:22:34
 Re: 560 power loss. What to do about it? in reply to Farmall Daddy, 11-13-2003 07:35:46
Your horsepower loss could be caused by several different things. From what you are describing, I would suspect leaky valves and/or leaky intake gaskets.
Aces
11-13-2003 10:03:01
If it is original it should have 3-9/16 bore and you will have to bore to but bigger in.
