removing stuck wheel weight bolts
joe
11-13-2003 11:28:51
have some weights mounted on inside of rim(farmall 350) and want to put on outside.they are half wieghts so tire does not have to come off. bolts are frozen solid from paint mainly and age. whats a remedy. already broke one socket just trying. paint remover?, mini propane torch?
Slowpoke
11-14-2003 00:31:53
 Re: removing stuck wheel weight bolts in reply to joe, 11-13-2003 11:28:51
I removed outside wheel weights from a Case a while back. Some of the bolts were frozen in the holes and some were loose but all the nuts were rusted fast. I used an impact socket and 3/4 drive ratchet with a cheater bar. The nuts broke off the frozen bolts without moving, and I used a big pipe wrench to hold the loose bolts untill the bolt twisted in half. A large punch knocked out the broken bolts.
Be sure to be out of the way BEFORE the weight drops off.
rustyfarmall
11-13-2003 13:56:43
I doubt very much if the paint has anything to do with it. Those bolts are more than likely rusted solid, you will need either an air impact, or an oxy-acetylene torch, and heat the area around the bolt, you won't hurt the cast-iron wheel any. I encountered the same thing a few years ago, I thought penetrating oil and patience would solve the problem, but after about 3 weeks, I ran out of patience, and went for the torch. Problem solved.
Haas
11-13-2003 12:48:11
I assume you have access to the nut. If so, take a cold chisel and a good heavy hammer and cold chisel a good notch on one of the flats. This should breal the nut loose and expand the nut enought that you should be able to take a wrench and get it off. If the bolts are stuck in the holes after you get the nut off, then screw a nut half onto the end and then another bolt into that nut. Now you can use a good heavy hammer to knock the bolts loose without damage to the treads of the bolt.
scotty
11-13-2003 12:10:42
Joe, I had the same problem, although I took tires off and used a hacksaw to saw through one side of the nut and then used a cold chisel and small hand sledge hammer. I used this method on my Super A but Im sure it will work for you as long as you have access to the nut.
scotty
