230 left brake
Ben.So.Tex
11-13-2003 15:25:18
This brake hang up when I step on it, I have to tap the shaft back in to make it release, this tractor sat for a few years,What might be the hang up, help me if you can, I sprayed some oil in it yesterday,but have not try it today to see if helped any, I've been green all my life ..FYI (I am not stepping on the brake lock)
Hugh MacKay
11-13-2003 18:00:38
 Re: 230 left brake in reply to Ben.So.Tex, 11-13-2003 15:25:18
Ben: Inside that brake is an double plate with balls between them that roll up a ramp as brake is activated. These usually are just dirty and or rusty and need cleaning. Anything that causes those balls not to roll freely will create problems. There are also springs that deactivate the brake, and if broken will also cause problems.
Also once brake discs wear beyond a certain point those balls travel further thus making either of the first two problems I mentiond even worse.
I have been a Farmall man all my life, having owned 16 of them, most bought new or near new, but I did have one Deere. I will conceed, you are used to better brakes.
Ben.So.tex,
11-14-2003 14:14:55
 Re: Re: 230 left brake in reply to Hugh MacKay, 11-13-2003 18:00:38
Thanks Hugh,,Later Ben
