Need help!!
earl in Pa
11-13-2003 17:19:21
How do you change a positive ground battery to a negitive ground. Do you need to change the generator or voltage regulator. Thanks in advance.
CNKS
11-13-2003 18:24:15
 Re: Need help!! in reply to earl in Pa, 11-13-2003 17:19:21
Unless you are converting to an alternator there is no reason to change.
gene b
11-13-2003 18:07:18
Beter check your regulator to see which ground it requires it should say on the bottom. You could burn it if you use the wrong ground.
Adam
11-13-2003 17:53:34
If i was going to change to neg ground. . .
I'd also convert to 12v, and put an alternator on it too. The only thing you need to worry about is that the AMP guage will read oposite, unless you switch the wires on the back.
ABW
