Looking for recomendations for sleeve kit (300)
Kelly C
11-13-2003 19:42:18
Getting ready to get ready :-)
I will be pulling the motor soon. I would like to get the most HP I can and still not beak the bank on the kit.
Also was thinking I should send the head out to get redone. Any one know of a place around MPLS that does this work?
Dean E.
11-14-2003 16:29:23
 Re: Looking for recomendations for sleeve kit (300 in reply to Kelly C, 11-13-2003 19:42:18
Have you tried Trappers Machine Shop in Bethel,Mn Wally Vanden Eykel 612-434-7378
Kelly C
11-14-2003 17:00:38
 Re: Re: Looking for recomendations for sleeve kit in reply to Dean E., 11-14-2003 16:29:23
Nope but I will. Thats right on my way to work also.
justin
11-14-2003 15:06:45
If you decide to get a stepped head piston & sleeve set, make sure your cylinder head has not been replaced with one from an H. I know several people that have run into this problem, and the results are not pretty, as the piston makes contact with the cylinder head.
randy hall
11-14-2003 09:55:12
kelly if you want to get the most for your money you should get prices from mike bunck at the steel wheel ranch.
Jim J
11-14-2003 07:41:22
I can get you a set.
gene b
11-14-2003 05:12:49
Sleeves and pistons start at 325 they even have a discount on now.
Kelly C
11-14-2003 12:22:21
 Re: Re: Looking for recomendations for sleeve kit in reply to gene b, 11-14-2003 05:12:49
Gene who is they?
gene b
11-15-2003 02:24:04
 Re: Re: Re: Looking for recomendations for sleeve in reply to Kelly C, 11-14-2003 12:22:21
KELLY send an e-mail i can give some more suppliers close to you.
Doc
11-13-2003 21:51:28
Try Wagamon Bros. at 37 & University on th Mpls. and Col. Hgts. border. I've gotten 2 engines from them with god luck. I am impressed by their facility and workmanship. Doc
Kelly C
11-14-2003 12:21:23
 Re: Re: Looking for recomendations for sleeve kit in reply to Doc, 11-13-2003 21:51:28
Cripes I drive by them almost every day.
I will make a stop.
John A
11-13-2003 20:34:23
Kelly, TRY,
1 Abilene Machine @ Abilene, KS--800-255-0337 or Belmond, IA--800-866-1504
2 O.E.M. Tractor Parts @ Bloomington, IA--800-283-2122
Prices seem to be good from either place. Difference might me the cost of freight! OBTW when I had a new clutch,P.plate,throwout bearing & TA put in my 966,(3 yrs ago) they came from Abilene machine. I don't have a current Abilene Catalogue. The price from OEM is about $700 to $750for everything. None the less call and get the catalogues. Hope this helps! Keep us posted on your progress.
Good Luck,
John A.
Kelly C
11-13-2003 21:13:38
 Re: Re: Looking for recomendations for sleeve kit in reply to John A, 11-13-2003 20:34:23
Thanks John.
I found the web site for Abilene Machine.
They have fair prices I think.
I noticed they have rebuilt TA's for my 300 for $489. Might be getting one of those. Will have to see if I can rebuild the old one my self 1st.
