560 PTO ADJUST
OROD
11-13-2003 20:32:46
HOW DO YOU ADJUST PTO ON A 560,I REMOVED PTO FROM TRACTOR BECAUSE PTO WOULD NOT DISENGAGE EVERYTHING LOOKS OK BUT I CAN NOT GET PTO TO KNUCKLE IN NO MATTER WHICH WAY I ADJUST IT. (OFF THE TRACTOR)
ken
11-14-2003 18:35:19
 Re: 560 PTO ADJUST in reply to OROD, 11-13-2003 20:32:46
had my 460 ute pto off last year cause it would'nt engage and on the bench it worked fine ended up it was the linkage from the arm to the pto.and you say it won't disengage by this do you mean it always turns,i know lots of em turn all the time but if you have a little load on it it won't mine turns all the time but if i hook my mower up to it it won't
OROD
11-15-2003 08:00:27
 Re: Re: 560 PTO ADJUST in reply to ken, 11-14-2003 18:35:19
THE ORIGINAL PROBLEM WAS THAT IT WOULD NOT DISENGAGE (stop turning) WITH OR WITHOUT A LOAD AFTER TAKING IT OFF & TRYING TO ADJUST, IT ENGAGES & DISEGAGES BUT NOW IT SLIPS WHILE UNDER LOAD. THANKS FOR YOUR HELP
Steve (MD)
11-14-2003 15:29:02
I just finished overhauling my 460's pto-should be same. It is a clutch type that you have to remove to adjust. There are only a couple of turns of the spider that are in the range for it to go overcenter. With the clutchpack facing up and the clutch disengaged, turn the spider until you can barely see any slack in the discs (none if any are warped). Keep tightening it and check to see until it goes overcenter with a snap. Once it does, keep tightening until it won't go overcenter, then back off a 1/3 to 1/2 turn and put it back together. If the adjustment doesn't work, check to see if the woodruff keys are shot or the pin through the shift yoke is sheared off. The shop manual will tell you how to adjust the clutch brake linkage. Email me if you need more info.
OROD
11-15-2003 07:43:28
 Re: Re: 560 PTO ADJUST in reply to Steve (MD), 11-14-2003 15:29:02
STEVE,I TRIED TO ADJUST IT EVERY WHICH WAY I COULD THINK OF WHEN I HAD IT OFF THE TRACTOR BUT I NEVER COULD GET IT TO SNAP,THOUGH I DIDN'T HAVE IT WITH CLUTCH PACK UP LIKE YOU ADVISED,COULD THAT BE WHY? IT SNAPS IN & OUT FINE WHEN INSTALLED IN TRACTOR,BUT NOW IT SLIPS BECAUSE I DIDN'T ADJUST IT RIGHT. STUMPPED THANKS FOR YOUR HELP
Steve (MD)
11-15-2003 16:36:59
 Re: Re: Re: 560 PTO ADJUST in reply to OROD, 11-15-2003 07:43:28
If it goes overcenter when installed on the tractor, you are close, and it should have gone overcenter on the bench. I'm guessing you are not getting enough leverage on it when you have it off the tractor. What direction it faces is not important. If you can't get it to go overcenter off the tractor, the next best thing is to keep tightening it until it doesn't slip when under load when installed on the tractor. Having taken mine off a couple of times, I know this is a pain. Try half a turn and with luck, you should be back in business.
Aces
11-14-2003 05:16:29
There are 2 PTO's for 560 so will need to know which you have the old old is band type with 2 bands about 2" wide the newer has a clutch pack in it.
OROD
11-14-2003 06:23:01
 Re: Re: 560 PTO ADJUST in reply to Aces, 11-14-2003 05:16:29
THIS ONE HAS A CLUTCH PACK.
THANKS FOR YOUR RESPONSE
Aces
11-14-2003 12:41:36
 Re: Re: Re: 560 PTO ADJUST in reply to OROD, 11-14-2003 06:23:01
The clutch is overcenter for engage and has a lock on handle for disengage. Don't know how much help I am
