300U into a 504U
KJM
11-14-2003 17:14:29
I have a 504U with a bad rear hub(cracked)will a rear hub from a 300U fit?
dick
11-15-2003 08:00:38
 Re: 300U into a 504U in reply to KJM, 11-14-2003 17:14:29
Part number for the 300U hub is 361583R. If that matches what's on your 504, you should be in good shape. If not, be careful. Good luck in either case.
kjm
11-16-2003 21:59:19
 Re: Re: 300U into a 504U in reply to dick, 11-15-2003 08:00:38
Thanks Dick I will check that # Monday. KJM
