10-20 help
M.Smith
11-15-2003 08:38:39
The 10-20 that I'm looking at has a number on bottom of transmission housing 28DB does this tell the year? Also the axle housings look different than normal 10-20's and the casting number on the housings is 1811D any clues?
Mike
Dale13
11-16-2003 05:00:39
 Re: 10-20 help in reply to M.Smith, 11-15-2003 08:38:39
I think I'm right in saying that the 1811D is a casting code.18th of november and D stands for 1932. I know my SM is a 53 year code Y.Counting back from that I got 32.
Nebraska Cowman
11-15-2003 16:04:33
no, that is a part number. You should find a month-day-year number cast in.
terry
11-15-2003 15:57:13
you should have a tag under the gas tank that has the serial number. it also says that the tractor has 20 hp at the belt pulley and 10 hp at the drawbar, hence, 10-20.
