WD 6 won't run
steve
11-15-2003 15:34:17
My WD 6 lost fuel pressure and quit. I replaced the fuel filters,now I have good pressure but it misses, I cracked the lines on the injecters and on #3&4 cyls it doesent change it .they both have fuel at the injecter. Could it be the injectr is bad? Any help is appreciated
Greasy John
11-15-2003 15:43:08
 Re: WD 6 won't run in reply to steve, 11-15-2003 15:34:17
Steve, How long did you bleed the lines to the cylinders that wont fire. sounds like air lock to me---BUT if you got water thru to the injectors it sometimes wrecks the nozzle. I am not that familiar with IH injectors but cat and cummins are bad about water into the injectors. One and a half cents worth? John
steve
11-16-2003 06:39:04
 Re: Re: WD 6 won't run in reply to Greasy John, 11-15-2003 15:43:08
Thanks Jim, I had the lines cracked open for a couple minutes each
