coil wire
Brooks
11-16-2003 10:36:23
Been reading the posts on 12v conversion and wondered with the 12v coil where the coil to distributor wire goes? and is it true you don't need a ballast resistor?
Bob
11-16-2003 11:07:26
 Re: coil wire in reply to Brooks, 11-16-2003 10:36:23
Negative ground tractor... Power wire from ignition switch to (+) side of coil. Wire from (-) side of coil to breaker points/condensor.
Positive ground tractor... reverse the above connections.
Does that answer your question about where the wire goes... I'm not sure I understood what you were asking?
And, yes, it is true you do not need a ballast resistor IF YOU HAVE A 12 VOLT COIL SPECIFICALLY LABELLED "NO EXTERNAL RESISTOR REQUIRED".
