Farmall 460 compression
Paul
11-16-2003 16:16:28
What kind of reading should I get when checking the compression and what would the valve clearance be set at when engine is cold? Thanks, Paul
Paul
11-17-2003 15:13:16
 Re: Farmall 460 compression in reply to Paul, 11-16-2003 16:16:28
It is gas Aces. Thanks for the info Steve. It looks like at least a valve job. Best I got on two cylinders was 120psi. Other four much lower. It was poppping pretty good through the exhaust.
Steve (MD)
11-16-2003 20:00:02
Compression: Gas 155 psi
Diesel 350 psi
LPG 205 psi
Valve Clearance (Manual only gives hot, all engines): 0.027
Aces
11-16-2003 17:38:36
Gas or diesel
