Farmall M 1st gear
Don
11-16-2003 18:38:29
Hi, I got a M tractor not running. So I can't try it to find out what first gear is in it. Can somebody tell me what the gear could look like? Regular 1st and slow first? I want a slow first in this tractor. I have the cover off the rearend. Any help would be appreciated. Thanks, Don
Haas
11-17-2003 18:15:50
 Re: Farmall M 1st gear in reply to Don, 11-16-2003 18:38:29
Like Dale says the gear is cut into the counter shaft if you have the extra low gear. The reason is, the gear is too small to make one to go on the shaft and so they cut it directly into the shaft. Due to this, the 2nd gear on the counter shaft is separate. On the regular gears, the 1st and second gear on the counter shaft are made together as a double gear. Lot's of stuff to change to put that low low gear in there, and I think nearly impossible to find the parts. I would say if you found an M that had that it would double it's value.
Don
11-17-2003 19:40:32
 Re: Re: Farmall M 1st gear in reply to Haas, 11-17-2003 18:15:50
Hi! Thanks for reply. What do I need to change to put first low in? I think I know where to get the parts. How many gears do I need to change? Thanks, Don
Dale13
11-17-2003 02:36:11
If you have the optional low first gear the bottom shaft in the transmission will have gear teeth cut right in the shaft instead of having a gear on the shaft.
