C Farmall pulling tractor
PA tractor pull
11-17-2003 14:45:11
I am building a pulling tractor out of a C Farmall. I cant bore the block very much because it is wet sleeved and I have always been told that you could swap out a C motor with a 203 combine motor. Has anybody got any input or information about how I can make my C hotter or if the 203 motor will work?
Kevin
11-20-2003 15:23:07
 Re: C Farmall pulling tractor in reply to PA tractor puller, 11-17-2003 14:45:11
I built a Farmall Super C a couple of years ago and got 160 cubic inches out of the motor without stroking. You can bore the block quite a bit but you have to then seal it all up. I used hard block and haven't had any trouble and the tractor runs great. Just my 2 cents
andy
11-18-2003 02:36:39
the 203 motor will work. put a 504 intake on it and wd45 carb. then go and have fun
