clear me up please
Buster
11-17-2003 15:21:54
Will the M wiring diagram work for a Farmall 100. And the 10SI is the "three wire alternator" ? And do you have to have the test light for the system to work? Thanks
Do you have a diagram for a 100?
little john
11-17-2003 18:08:38
 Re: clear me up please in reply to Buster, 11-17-2003 15:21:54
Bob M will probably answer with a wiring diagram. I used the 10SI on an H, and it is three wire. I believe you need the light to prevent battery feedback to the alternator, altho' I am not a very good electrician. I followed Bob M's diagram and everything worked well.
Rich
11-17-2003 15:42:58
I converted an H to 12 volts. I went to the local dealer and they had a plug that went into the alternator. That plug had a diode in it so I didn't need the light.
Buster
11-17-2003 16:06:37
 Re: Re: clear me up please in reply to Rich, 11-17-2003 15:42:58
Is there a 3 wire 10SI and a one wire 10SI and if I use the single wire will I need a diode or light?
Dan
11-17-2003 18:57:20
 Re: Re: Re: clear me up please in reply to Buster, 11-17-2003 16:06:37
Yes there is a single wire 10SI. Only one wire and no need for lamps or diodes. I believe it is the marine version.
