International 600 hydralic leak, help
IH JON
11-17-2003 16:36:11
I am having a very difficult time fixing a leak that is coming between my valve and end plant. This is mounted up just in front of operater on right hand side when sitting in seat. The operating lever is located here also. My leak seems to be coming between the end plate and the valve. I have gone through and replaced all of the o rings and have even tried to put just a little form a gasket to help and it still is leaking. It is a slow leak but still a leak. I have thought about machining the endplate but not sure if I could do that? Has anybody else run into anything like this? Or have any suggestions about what can be done?
thanks IH_JON
Red Rider
11-17-2003 19:52:46
 Re: International 600 hydralic leak, help in reply to IH JON, 11-17-2003 16:36:11
Jon, are you using the correct size O Ring. The IH part number for the correct O ring is 350 667 R1. If the OD of the is not exact it will leak.
ih jon
11-19-2003 16:56:44
 Re: Re: International 600 hydralic leak, help in reply to Red Rider, 11-17-2003 19:52:46
Yes, I have replaced using the same part number you have given. The number has been changed and is now 238 5115. I just double checked this to be sure in my parts book. Thanks for your help. Would you happen to have any other suggestions?
thanks
ih jon
