? about 544 Int.
kelly
11-17-2003 18:55:03
Int. 544 sitting in barn for 15 years.Tires are flat tractor is strait paint is fair was running when parked.What is it worth and how many horse power is it?
Gramps544
11-18-2003 14:05:43
 Re: ? about 544 Int. in reply to kelly, 11-17-2003 18:55:03
I-554 value....I would say Zero!!! I will take it off your hands for that.In running condition it worth a few thousand. Let me know if you are parting it out. I need some parts.
old
11-17-2003 19:31:42
Its around 52 HP, as far a valve it could be very little to around a few thousand depending on a lot of thing. But with flat tires and hasn't run in years probably a few hundred, if the engine isn't stuck maybe around $1000. Really need more info to say and then its still a guess.
Hope this helps
kelly
11-17-2003 19:46:34
 Re: Re: ? about 544 Int. in reply to old, 11-17-2003 19:31:42
Thanks old thats what i needed to know.
CHRIS IN TX
11-19-2003 16:49:15
 Re: Re: Re: ? about 544 Int. in reply to kelly, 11-17-2003 19:46:34
WHERE ARE YOU LOCATED? GAS OR DIESEL,TRUST ME, IT WILL BE THE MOST POWERFULL 50 HP TRACTOR YOU EVER SAT ON. I HAD ONE AND WAS DUMB FOR SELLING IT.
kelly
11-23-2003 15:11:29
 Re: Re: Re: Re: ? about 544 Int. in reply to CHRIS IN TX, 11-19-2003 16:49:15
Im from TX
