A question for Big John
little john
11-18-2003 14:34:47
Regarding the smaller alternator that we were considering for a 12 volt conversion, is that Japanese alternator internally regulated like
the Delco? I assume that it is....thanks for
your thoughts.
Greasy John ( another Joh
11-18-2003 18:10:21
 Re: A question for Big John in reply to little john, 11-18-2003 14:34:47
Tnx Big john--Just finished adding the Napa rebuilt you used on my 350 farmall --Used a belt 1/2" shorter and ground a bit on the front of the original mount bent the adjuster in an offset 1" Used a 5/16 rod for the bolt as my napa dealer said if I drill out the mounts they may not warranty or except it for a core?? Makes great looking install again Tnx. Greasy John (Or.)
BIG JOHN
11-18-2003 17:23:18
Everything in one small package. Regulator, resistor to stop any back feed, etc. You won't need anything else as far as the alternator is concerned. If you are keeping the orginal coil you will need an externat resister for it, if you have a mag then you are home free.
GOOD LUCK
