Leaking Head gasket??
Jason B.
11-19-2003 06:32:31
I just replaced the cillinder head on my 460 diesel a few weekends ago. I was working on it the other day and as it was running i noticed i could see air bubbles between the block and head(injector side). Ive retorqued the head multiple times hot and cold and it still leaks. but when its running it doesent smoke or anything. Is it a faulty gasket or my mistake. Any clues to what might this be?
ro
11-19-2003 13:59:28
 Re: Leaking Head gasket?? in reply to Jason B., 11-19-2003 06:32:31
On my 560 D, after having the head worked on, including planed, I was cautioned to use new head bolts and to also make certain that they weren't "bottoming out" in the engine block, prior to actually putting the designed for "squeeze" on the head gasket.
When I checked the new bolts from IH, I thought they were too close to possibly bottoming out, so I ground them off a slight bit. Put it together per recommended torque and haven't had any problem.
Jason B.
11-19-2003 18:06:58
 Re: Re: Leaking Head gasket?? in reply to ro, 11-19-2003 13:59:28
The head was welded up and brought back to original specs.
RO
11-21-2003 18:01:30
 Re: Re: Re: Leaking Head gasket?? in reply to Jason B., 11-19-2003 18:06:58
I'd still confirm that the head bolts aren't too long.
Jason B.
11-19-2003 10:08:32
I made sure the block was true i filed down the area over the bolt holes like the book said to. I also did not use any sealer. any more suggestions?
Randy in NE
11-19-2003 09:20:15
Did you check to make sure that the surfaces of the head and block are true? If either of them are slightly warped you are going to have head gasket problems.
Allan
11-19-2003 06:40:24
Hi Jason,
I'd keep an eye on it, but I doubt if you have anything to worry about.
It is probably just cooking out that sealer you used.
Watch the fluids for a time, tho.
My opinion,
Allan
