706/915 firing order
Rob
11-19-2003 10:20:25
I have a 706 that has had the engine replaced with one out of a 915 combine according to the guy I bought it from. Several cyliders appear to not be firing. The way the plug wires are arranged now is not the way the 706 book shows. Would the 915 have a defferent firing order for the same engine? If so does anyone know what that firing order should be?
Jim was in UK
11-19-2003 11:38:34
 Re: 706/915 firing order in reply to Rob, 11-19-2003 10:20:25
I know it has been a few years (18 now) since I worked as a mechanic in a repair shop. But generally speaking, most all 6 cylinder engines have a firing order of 1,5,3,6,2,4. I would find the # 1 on the distributor cap and go with it from there. Hope this helps you out with your problem.
later days mate,
Jim in NM again
Allan
11-19-2003 15:09:23
 Re: Re: 706/915 firing order in reply to Jim was in UK, 11-19-2003 11:38:34
Jim,
Some things ya just never forget do you? :>)
Kinda cool when you can just rattle that off from memory like that.
Allan
Rob
11-19-2003 16:58:40
 Re: Re: Re: 706/915 firing order in reply to Allan, 11-19-2003 15:09:23
The old girl sounds so much better firing on 6 instead of only 3 cylinders. Once I figured out which post on the dist #1 was supposed to be in I had it made. Thanks for the help.
