12 Volt coil
Chester
11-19-2003 10:40:31
If I buy a 12V coil with resistor inside does that do away with the ballast resistor on my 12v conversion?
Doug in OR
11-19-2003 11:42:33
 Re: 12 Volt coil in reply to Chester, 11-19-2003 10:40:31
Yes, you no longer need the ballast resistor. In fact, it will decrease performance if you use a ballast resistor with a 12 volt coil.
