Farmall H Rear Tires
Brian Schmidt
11-20-2003 12:12:29
I am getting ready to put a new set of tires on the rear of a Farmall H and am wondering what size most guys are puitting on. It has 12.4X38 now. One dealer told me that 11.2X38 or 13.6X38 would also work.
Harold H
11-20-2003 13:53:39
 Re: Farmall H Rear Tires in reply to Brian Schmidt, 11-20-2003 12:12:29
I think the H looks best with 11.2 or 12.4 tires. 13.6 or 15.5 look too big IMHO.
Harold H
Allan
11-20-2003 14:04:05
 Re: Re: Farmall H Rear Tires in reply to Harold H, 11-20-2003 13:53:39
Run for mayor, Harold. I'll vote for ya.
Allan
jal-SD
11-20-2003 12:59:00
Grew up on H's. We farmed 880 acres of row crops with 4 of them during the 1950's and early '60's. One of the two we used the most had 11-38's (now 12.4's) & the other one 10-38's (now 11.2's) from the factory. Later put on 12-38's (now 13.6 size) on both-I wouldn't go any bigger than that, as the both 11's & 12's were about the best in putting all the torque to the ground that the H's were able to produce. Neighbor had a Super H that he put a set of 13-38's on that he took off his M when he went to 14's on it-our H (w/a 2 year old set of 12's) that had a gas head and oversized pistons in it could out pull his Super H in tough going. He'd have to go to 2nd pulling 2-16 plow & we could pull right through the same hard pan in 3rd. We were pulling a Case plow, he had an IH & Case plows pulled harder than IH's did. (He claimed his IH pulled harder until we switched plows & then he didn't argue any more.) Neither tractor had traction problems, his Super H simply wasn't geared right to use the bigger tires, we all felt. That Super H always looked like it was going down hill with those 13's on it. IMHO, I would go with the 12.4's. (My $0.02 worth. jal-SD)
CNKS
11-20-2003 18:15:45
 Re: Re: Farmall H Rear Tires in reply to jal-SD, 11-20-2003 12:59:00
I agree on the tire sizes, but remember the SH has a 5 mph 3rd in it, the H, I think, is 4 1/8. The faster 3rd gear may cancel out the advantage of the additional 4 or so SH hp. And, since your H had larger pistons, it probably was close to the SH in power, and with the lower 3rd gear, it stands to reason that you could outpull his in 3rd.
