Bent Steering Shaft
Ken
11-20-2003 15:03:19
A large limb fell across my Super AV. The steering shaft has a bend that keeps the SAV from turning.
I have removed the shaft but need advice on how to straighten the shaft.
David A
11-20-2003 16:20:06
 Re: Bent Steering Shaft in reply to Ken, 11-20-2003 15:03:19
These methods may sound crude they have worked for me on long steel things needing straightening.
1. Find a couple trees close together, position the shaft between them and pull.
2. I've been able to hammer rods straight against a long anvil (actually a piece of railroad track).
3. Support it using a vise and a block of wood on the garage floor. Then lower something heavy on it (like the rear tractor wheel slowly let down with a hydraulic jack).
I'm open to other menthods.
Good Luck,
David
rustyfarmall
11-20-2003 16:10:48
Lay it down on a solid concrete floor with the bend up, and start beating it with a big hammer, sounds rather crude, but it works. Your other option is to find someone with a hydraulic press.
